All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #31
Old 22-10-2012, 03:23 AM
Larirel's Avatar
Larirel Larirel is offline
Registered User
Larirel is on a distinguished road
I recently found that the alternator was bad. I have replaced the alternator and a new dry cell battery. I have tested both the battery and the alternator and I know that they are good.
__________________
check out here
  #32
Old 23-10-2012, 01:01 AM
SDK SDK is offline
Banned
SDK is on a distinguished road
Repeatedly charged battery will reduce the battery life of the
  #33
Old 29-10-2012, 04:38 AM
amparolordd's Avatar
amparolordd amparolordd is offline
Registered User
amparolordd is on a distinguished road
go get your charging system checked,,sounds like your alt is weak,,needs to be overhauled.
__________________
find more information
  #34
Old 29-10-2012, 10:09 PM
soham's Avatar
soham soham is offline
Registered User
soham is on a distinguished road
I think u should immediately get your battery replaced .
__________________
The Zero Debt Club - FREE To Join $100.00 Sign Up Bonus!
Click This Club Members Rotator Link For The Details
The SUPER HUGE Paychecks In Empower Network Is Simply "Bad Ass"!!!
Click This Photo Link To Watch The Video
Ads
  #35
Old 31-10-2012, 06:00 AM
Milaunisexcel's Avatar
Milaunisexcel Milaunisexcel is offline
Registered User
Milaunisexcel is on a distinguished road
right now i disconnected the battery and im going to let it rest for a 1/2 hour and see if it does any good ...
__________________
get more
  #36
Old 31-10-2012, 11:30 PM
soham's Avatar
Registered User
I think your alternator is not good enough to use thats why you are facing such problems.
Thank you
__________________
  #37
Old 30-11-2012, 03:41 AM
SDK SDK is offline
Banned
The battery is not as long as possible, to no protection circuit of the battery filled namely should stop charging, or cell because of fever or overheat impact performance
  #38
Old 01-12-2012, 07:43 AM
soham's Avatar
Registered User
Quote:
Originally Posted by e90i View Post
Hi, guys I have a battery display problem, the battery bar wouldn't show the correct battery remaining, but i found out that everytime my screen flash 2 times then the battery bar with drop but sometimes wouldn't, sometimes it with hang and my battery can't last for 2 and half days(note when I brought new it can last) I did change to new battery as I thought battery already k.o.
Thanks Regards
I think your charging system is out of order. Get it checked.
__________________
  #39
Old 14-01-2013, 04:00 AM
SDK SDK is offline
Banned
Very thank you for your message, I do think samsung mobile phone battery life is also very good, like my battery life period can reach and hours of time, it brought me a lot of convenience and benefits of I don't have to worry about mobile phone battery will influence to my things
http://www.galaxynote2caseshop.com/h...te-2-28679.htm
  #40
Old 07-03-2013, 02:19 AM
RTGDJF RTGDJF is offline
Banned
RTGDJF is on a distinguished road
When the battery is not the longer the better, after the battery is full of no protection circuit which should stop charging, the battery will affect performance because of fever or overheating
Bookmarks
Tags
battery, problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Changing Skins, Side Schemes & Color Roman Nokia 9300 and 9500 571 22-09-2011 01:10 AM
REVIEW & TIPS: extending the battery life on the N95; acbTaskMan vs. Energy Profiler Menneisyys Nokia N95 and N95 8GB 36 23-05-2008 06:52 PM
Battery problem on N95 8GB Biggles71 S60 (Series 60) 0 16-12-2007 10:10 PM
A925 battery problem CarlX Motorola A920, A925, A1000, Benq P30 and P31 and Arima U300 2 08-10-2005 09:11 PM
Article: Battery Info CorruptedSanity Sony Ericsson P800, P900 and P910 7 03-03-2003 10:33 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
