ListBox woes (KERN-EXEC 3)
5 replies · 7,745 views · Started 05 March 2003
I'm wondering someone can help me with a ListBox problem. I'm trying to construct and display a ListBox in the container of my application. The ConstructL function looks like:
void CLbtestContainer::ConstructL(const TRect& aRect)
CreateWindowL();
iListBox = new (ELeave) CAknSingleStyleListBox;
iListBox->SetContainerWindowL(*this);
iListBox->ConstructL(this, EAknListBoxSelectionList);
array = new (ELeave) CDesCArrayFlat(5);
array->AppendL(_L("\tItem1"😉);
array->AppendL(_L("\tItem2"😉);
array->AppendL(_L("\tItem3"😉);
array->AppendL(_L("\tItem4"😉);
array->AppendL(_L("\tItem5"😉);
iListBox->Model()->SetItemTextArray(array);
iListBox->CreateScrollBarFrameL(ETrue);
iListBox->ScrollBarFrame()->SetScrollBarVisibilityL(CEikScrollBarFrame::EOff, CEikScrollBarFrame::EAuto);
SetRect(aRect);
ActivateL();
Everything compiles fine but when I run it in the emulator it instantly crashes. When I run it on my target device (3650) it immediately exits with a KERN-EXEC 3 panic. I've looked up the panic message but I'm still lost on what could be causing the problem. I would appreciate any feedback you can give. Thank you!
Regards,
Dennis
What does your
TInt CLbtestContainer::CountComponentControls() const
return 1; // return nbr of controls inside this container
and
CCoeControl* CLbtestContainer::ComponentControl(TInt aIndex) const
if (aIndex == 0)
return iListBox;
return NULL;
say?
Best regards,
Teemu Moilanen
First of all, let me start by saying that I don't know the CAknSingleStyleListBox class at all. It is not part of my sdk. But, having said that, here are some questions and a suggestion.
1. What is the exact definition of CAknSingleStyleListBox::ConstructL ?
2. What is the class name of the model used by the listbox ? (e.g. CTextListBoxModel)
3. Is the listbox constructing the model, or do you need to do it ?
I would suggest that you change the following code from
[code:1]array = new (ELeave) CDesCArrayFlat(5);
array->AppendL(_L("\tItem1"));
array->AppendL(_L("\tItem2"));
array->AppendL(_L("\tItem3"));
array->AppendL(_L("\tItem4"));
array->AppendL(_L("\tItem5"));
iListBox->Model()->SetItemTextArray(array); [/code:1]
to [code:1]CDesCArray* array = (CDesCArray*)iListBox->Model()->ItemTextArray();
array->AppendL(_L("\tItem5")); [/code:1]
A couple of things to try:
1. Swap the ConstructL() and SetContainerWindowL() lines around.
2. Add the line
[code:1]iListBox->Model()->SetOwnershipType(ELbmDoesNotOwnItemArray);[/code:1]
before calling SetItemTextArray().
Thanks for the great responses and I did finally come to a solution and it was what emunator suggested. My ComponentControl function was still referencing the default labels inserted by the AppWizard. Thanks for taking the time to help a newbie out and I'm glad to be a part of these great forums!
Regards,
Dennis
CreateWindowL();
SetRect(aRect);
ActivateL();
Regards,
Dennis
can any body tell me which library is used to access listbox controll for class CAknSingleStyleListBox
i got an error
c:\Symbian\7.0s\Series60_v20\Epoc32\CarSample\inc\CarSampleContainer.h(87): error C2079: 'CCarSampleContainer::iListBox' uses undefined class 'CAknSingleStyleListBox'
c:\Symbian\7.0s\Series60_v20\Epoc32\CarSample\src\CarSampleAppUi.cpp(188): error C2065: 'array' : undeclared identifier
but If i declare
class CAknSingleStyleListBox; // For List Box
class CDesCArrayFlat; // Array
then it will reduce error list and return few errors like
C:\Symbian\7.0s\Series60_v20\\Epoc32\include\badesca.h(213): error C2371: 'CDesCArrayFlat' : redefinition; different basic types
c:\Symbian\7.0s\Series60_v20\Epoc32\CarSample\inc\CarSampleContainer.h(21): fatal error C1001: INTERNAL COMPILER ERROR
(compiler file 'msc1.cpp', line 2701)
Please choose the Technical Support command on the Visual C++
Help menu, or open the Technical Support help file for more information
can anybody solve my problem so i can provide me solution as early as possible.
I want to read contact numbers and put it into listbox for display
can anybody tell me how can i do this ?
Thank you.
Chirag
