Nokia 5800 - I can't install anothers softwares !!! :-(
7 replies · 6,082 views · Started 19 June 2009
I ended up doing the famous "* # 7370 #" to reset my Nokia 5800.
So I got my bar contacts. Cool!
For against, I have installed the new apps that I had before and without obvious reason now I can not install any program.
Does anyone has encountered the same problem as me?
Does someone have a solution?
Thanks for your help.
ThieRy
tnaquin wrote:Hi,
No, what you did should not prevent installation of new apps.
2 things:-
1. In future install all your apps to memory card instead of internal memory where possible - then formatting internal memory would not wipe out your apps.
2. What error or message do you see when you try to re-install apps?
dez_borders wrote:No, what you did should not prevent installation of new apps.
2 things:-
I have no message !!!
I have the first screens of information: name and version number of the application, warnings, ... and when I should have the screen with the message Installation I've got nothing and the program name scroll again ...
ThieRy
i also have the same problem.
when i try to install any application it shows "Expired Certificate".
after reseting the phone i can install the applications but later it doesn't install
