Is anyone using XP Pro,Socket Bluetooth CF card with PC Card adaptor & the new PC Suite 1.2.0 for XP successfully.
Mine works right up until the point you try and download an image or program to the phone, when it drops the bluetooth connection !
I had this before with version 1.1.0 of PC Suite and put it down to PC Suite not being compatible with XP. It worked fine after I dual booted and ran it under Windows ME, so I concluded it wasn't the phone which is at firmware 3.16.
I have the same combination and the same simptom, just that I have XP Home. It is the same with Windows 2000 and earlier version of PC Suite, so I don't know what might be the problem. It works well with short data transfer like calendar synchronisation, Bemused, PC Remote etc., but it works also with Remote S60 where the data transfer is quite big and continous. The bluetooth connection drops in the same way when I connect to internet with null access point through bluetooth.
YrannAdX
What firmware version are you running ! I have heard that this may be an factor. I'm on 3.16 but haven't had an oppertunity to try and get it upgraded.
Jon
Does anyone have a link (or can make one available) to the XP drivers for Socket CF card? I bought mine secondhand and it didn't come with a cd.
Thanks!
