All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 23-10-2008, 08:18 PM
JerryCrockford JerryCrockford is offline
Registered User
JerryCrockford is on a distinguished road
Mac Modem connection with E71 via USB
I wanted to connect my MacBook to the net via my E71 using USB, so as to consume less power than by BlueTooth.
I followed the steps detailed at {http://www.2nrds.com/using-the-nokia-e71-as-a-modem-on-a-mac}, and it worked perfectly. :-)
But alas…
It only worked ONCE. :-(
A few days after setting it up, I tried again, but when I click on ‘connect’, the Mac tries briefly, then an INTERNET CONNECT alert appears on my Mac, saying “The selected communication device does not exist. Please verify your settings and try again.”
Hmmm….
I tried the Nokia Multimedia Transfer software connected by USB, and the “Device Browser” works fine, so the E71 IS connected OK using PC Suite. But for some reason, the Mac can’t see the E71 and connect through it as the modem.
Weird? As I said, it did it just fine the other day.
I haven’t changed any settings from when it DID work, and being a tek-nik-kal dim-wit, I don’t want to try anything in case I stuff it up.
A couple of other clues...
1. It works fine when I connect via Bluetooth.
2 The drop down menu shows the E71 on the list, but it is GREY, so not available.
So how can the E71 be connected with PC Suite — but the 'connect' thingy in System Prefs > Network thinks it does not exist? If you have any thoughts, I really would appreciate it!
Thanks!
Jerry
Ads
Bookmarks
Tags
connection, e71, mac, modem, usb
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
E71: seems impossible to share internet connection, any ideas? Arcteryx Nokia Eseries S60 3.1 Phones (2nd Generation: E51, E66, E71) 3 25-08-2008 11:50 PM
The multiplatform Bible of using your handset as a modem Menneisyys Nokia N95 and N95 8GB 11 12-07-2008 04:18 PM
USB PC Suite Connection problem with 6120c v3.83 dongperez Nokia 6110, 6120 and 6121 0 04-06-2008 05:50 AM
3230 as a modem over USB - won't dial mike_perth Nokia 3230 6 04-04-2006 09:01 AM
Wierd connection problem 6620 to mac computer parklife Nokia 6600 and 6620 1 16-03-2005 05:13 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
