All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
Go Back   All About Symbian Forums > Symbian Based Devices > S60 (Series 60) > Nokia N95 and N95 8GB
Reply
Thread Tools Display Modes
  #1
Old 30-11-2007, 11:48 AM
3Shirts 3Shirts is offline
Registered User
3Shirts is on a distinguished road
Phone Handset HOW TO: Change your product code (and why you might want to)
Why would you want to do this?
When new firmware is released, Nokia will only release the vanilla, or un-branded, firmware. This means that only unbranded (non-network specific) phones will 'see' it when running the update tool.
The firmware goes to the networks who modify it by adding their logos or themes (and in many cases disabling certain apps ) so that is why it often takes weeks for the network specific version of firmware to roll out. Changing your product code allows you to 'fool' the updater into thinking you have an un-branded phone and thus get the update sooner, without all the memory sapping themes and crap and with all the apps intact.
Is there a risk of damage?
No. There is a small risk associated with updating firmware but changing your product code does not add any additonal risk.
Does this harm my warranty?
If your phone is still within the manufacturer's one year warranty (or any extended warranty) this will void it. However, many of us on this forum have changed the product code and subsequently had the phone repaired at a service center under warranty. There is a risk they may discover you have done this and refuse to do the work under warranty but the risk is very small. There is also the moral question, but that is up to you!
Ok, I'm cool with all that, how do we do this?
To change product code you need Nemesis Service Suite (NSS): http://www.b-phreaks.co.uk/software.htm#downloads
  1. Install NSS and, while installing, accept the default for 'Virtual USB'.
  2. Once installed, connect your N95 to the computer by usb cable.
  3. Run NSS
  4. It wil be pretty blank at this point. Hit the magnifying glass to search for devices
  5. Once that is done (a couple of seconds) click on the Phone Info button and then, on the right hand side, click Read
  6. You will now see your product code which is a 7 digit number. If you plan to change this back after flashing then make a note of the current code (this is probably wise to do anyway although it is written under the battery in the back of the phone).
  7. Take a look at this thread and choose a product code you want to use (remember the codes for the N95 'classic' are different to the 8Gb). The code for EURO 1 is generally recommended for the classic N95. Obviously you don't want an operator specific code!
  8. Delete the current code and type in the new one in the Product Code box in NSS. Tick Enable and then press Write
  9. That is all there is to changing your product code. Easy huh?
Now you just need to update. There is a guide to that on the way
One you have updated you can, if you wish, change your product code back again by repeating this process and writing the old code.
  #2
Old 30-11-2007, 11:57 AM
evilweasel's Avatar
evilweasel evilweasel is offline
Registered User
evilweasel is on a distinguished road
....should be a sticky maybe ?
Ads
  #3
Old 30-11-2007, 11:59 AM
Matt.C Matt.C is offline
Registered User
Matt.C is on a distinguished road
Top post. Should save a few repeats. Defo a sticky i think.
  #4
Old 30-11-2007, 12:01 PM
Registered User
Quote:
That's what I'm hoping but who knows
  #5
bartmanekul bartmanekul is offline
Super Moderator
bartmanekul is on a distinguished road
Dont forget to add rep.
  #6
Old 30-11-2007, 12:49 PM
chrsfrwll chrsfrwll is offline
Registered User
chrsfrwll is on a distinguished road
Ha ha. You are kidding, right? Since when has anyone actually read previous posts when seeking information?
(Top post by the way 3Shirts)
__________________
PIM evolution: filofax > psion organiser > psion 3 > psion 3a > psion 5 > palm > palm v > handspring visor > ipaq > 9300 > N80 > N95 > iPhone 3G, oops
  #7
Old 30-11-2007, 02:07 PM
andykn andykn is offline
Registered User
andykn is on a distinguished road
Another good one.
I'd add that, when you install NSS accept the default for 'Virtual USB'.
And the phone's original Product Code can be read from the label on the back under the battery.
  #8
bigbadnewill bigbadnewill is offline
Registered User
bigbadnewill is on a distinguished road
Hey, how do i change the product code of my new n95-8gb then??
Only joking, cracking guide my friend. Maybe one day the world will realise that there is a search button!
  #9
Old 30-11-2007, 02:18 PM
Dogmann's Avatar
Dogmann Dogmann is offline
Registered User
Dogmann is on a distinguished road
@3Shirts
Very nicely done and also nice of you to take the time and trouble as this is easily the best and easiest guide to follow i have seen. Hopefully it will be a sticky and stop people having to ask how to do it repeatedly.
Marc
  #10
Old 30-11-2007, 02:22 PM
HoundDog HoundDog is offline
Registered User
HoundDog is on a distinguished road
Quote:
I'll second that, it took me quite a bit of SEARCHING to work that out the first time I installed it.
  #11
Old 30-11-2007, 02:28 PM
Registered User
Thanks, good advice. That's been added.
  #12
Old 30-11-2007, 04:45 PM
Registered User
Ok I don't mean to sound ungrateful but the sticky topic which uses my guide has been altered slightly, is missing the recent edits, my screenies are gone and there is no credit to me :(
  #13
Old 30-11-2007, 05:24 PM
stuclark's Avatar
stuclark stuclark is offline
Super Moderator
stuclark is on a distinguished road
Quote:
Your post is quite different from the one I posted, and while I'll admit it's something I've been meaning to post for a while, it's more luck than anything else that I had the time to do it today. You'll notice I placed a lot more emphasis on what the product code is and does, as this being a public website, and me being an admin on this site, I need to make sure that what's being posted is accurate and doesn't infringe on any rules / laws etc.
  #14
Old 06-12-2007, 04:55 PM
pac3 pac3 is offline
Registered User
pac3 is on a distinguished road
Just curious but:
is it as simple as it seems
is it legal
can nokia find out
It seems too good to be true. I really want to upgrade my firmware.
  #15
Old 06-12-2007, 05:05 PM
Registered User
Quote:
Originally Posted by pac3 View Post
Just curious but:
is it legal
can nokia find out
Yes, presumably yes, and don't see how unless you take the phone to a nokia repair shop but as has been said elsewhere they don't seem to care. It really is as easy as it seems, and takes seconds once the software is on your pc.
__________________
Reply
Bookmarks
Tags
change, code, product
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Changed product code but update fails riverboat Nokia N95 and N95 8GB 10 30-08-2007 12:25 PM
How to Update firmware to V 5 with Nokia Software Updater m80116 Nokia N80 0 22-08-2007 06:22 AM
E61 Firmware Update, Product code change, Language Effect? fuzzyhaha Nokia Eseries S60 3.0 phones (E50, E60, E62, E61, E61i, E70) 0 14-06-2007 12:42 PM
Cant change my product code back using NSS dazzyboi84 Nokia N95 and N95 8GB 3 06-06-2007 03:20 PM
N95 cannot update to latest firmware Ridwan Nokia N95 and N95 8GB 5 18-05-2007 12:26 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
