04-06-2007, 05:59 PM
Registered User
So has anyone actually got any on sale for order now? (As in not just pre-order?)
04-06-2007, 06:07 PM
Registered User
according to the top links comments someone, some people have got one.
EDIT
Found it for sale at $99, cant find it for UK though :(
http://www.verizonwireless.com/b2c/s...Memory%20Cards
bottom right of page
direct link http://www.verizonwireless.com/b2c/s...essoryId=28237
__________________
Nokia 3310 > Nokia N-Gage > Sony Ericcson K700i > Motorola E1000 (ugh)> Nokia N80 > Nokia N95 > Samsung Omnia i900 (no thanks) > Samsung i8510
05-06-2007, 07:02 PM
Registered User
Now Tomtom becomes a realistic alternative
Two Internet stores have it in stock in Sweden today. Friday, they did not. I checked.
With a 4 GB card, I may consider Tomtom as a GPS app. Before, I thought it was a really bad idea. I suppose the maps requires something between 0.5 and 1 GB. With a 4 GB card it's very much reasonable suddenly.
06-06-2007, 01:58 PM
Registered User
TomTom is the best GPS sw by far, I have maps on my N95 (no good) Wayfinder on my W950 and TomTom Navigator6 on my P990 its the only one worth buying, would you be able to use the inbuilt GPS reciever of the N95 with TomTom?
06-06-2007, 02:05 PM
Registered User
Quote:
I don't understand that sentence fully. But I wonder, what exactly do you prefer with Tomtom that you don't like with Wayfinder. (I assume that you compare with remodelled Wayfinder 7, not old version 6.)
06-06-2007, 06:56 PM
Registered User
TomTom with UK maps fits on a 256MB card, so 4GB for Tomtom isnt neccessary, as most countries are less than 300MB. Unless you're going for a lot of maps, or you keep alot of other stuff on your memory card.
__________________
06-06-2007, 10:15 PM
Registered User
Only Uk retailer is o2 stores
o2 has an exclusive on the cards till the 22nd of june, they have been in stock since the first in o2 stores and come supplied with a usb card reader/writer.
07-06-2007, 12:20 AM
Registered User
Quote:
Well, I wouldn't settle for anything less than Western Europe at least on my mobile phone. So what you say is a bit worrying. But I seem to remember that it wasn't that bad...
07-06-2007, 08:44 AM
Registered User
Quote:
I can't see them:
https://shop.o2.co.uk/accessories?fi...emory&x=32&y=9
I also want a 4GB card. I want a card that purely has all the GPS stuff on it. I also want to try out maybe 2 or 3 different packages on the same card and I want to make sure I have both the UK and pretty much all of Western Europe covered on all of the packages I use. So 4GB might even be a bit of a squeeze.
07-06-2007, 03:58 PM
Registered User
Cant find them on the o2 website, but o2 website only has 3 memory cards on it so not the best place to look. How much are they in o2 stores?
Anyone know when to expect imports on eBay?
__________________
07-06-2007, 05:55 PM
Registered User
No!!! Don't buy memory on eBay. Virtually every piece of memory for all the gadgets I have ever owned (which is quite a lot) when I bought memory off of eBay, it turned out to be fake.
It just isn't worth the risk
Strangely (for reasons I don't quite get yet) Amazon (since it did used to be expensive) have some really pretty dirt cheap prices these days - and if there ever is a problem, they are much easier to deal with than eBay is.
07-06-2007, 08:07 PM
Registered User
Fair point. How much are 4GB SDHC in o2 stores?
__________________
08-06-2007, 08:31 AM
Registered User
Picked up an 4gb card in O2 shop in Milton Keynes lastnight. £59 quid I think it was. Wasn't on the shelves but I called to confirm stock and they had them in the back. Took it home and copied my 2gb card to the new card, which comes with a USB reader and a SD adapter. Back in the phone and it works a treat. Very happy. Have tomtom6 Western Europe installed (950 mb), nokia maps for uk and most of France (~300mb) and about 850mb of MP3s plus odds and sods and still have 1.8gb free!
08-06-2007, 12:43 PM
Registered User
Brilliant! And here's me just went and bought another 2GB card (so 3 in total now) last night when I figured that stocks would be scarce for a long time and prices would be very high. £59 quid though isn't too steep.
Oh well, I guess the only consolation is that the 3 x 2GB cards were still cheaper than the 1 4GB card. Not that I care. I'm lazy. I don't want to have to keep swapping cards. With the 4GB I can pretty much have all three GPS packages (TomTom, Route 66, and the Native GBS 'Maps' package) on one card. Or at the very least I can have one package, with the largest part of the world covered, which is probably more sensible once I have worked out which package I like best (although I don't think I will be able to do all of America too as this is usually about 4GB+ on its own). What we really need is a minimum of 8GB - but that isn't projected to happen for another 2 years at least.
Just out of interest, since there have been so many conficting reports (some say it does work, some say that it doesn't) can you tell us what 'brand' your phone is (if any) and what firmware version you are using?
Thanks!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
