All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 12-04-2007, 03:08 PM
adz06 adz06 is offline
Registered User
adz06 is on a distinguished road
MSN on the N95?
Hi
Is it possible to get an MSN Messenger application for the N95? I've looked at some of the software listed on here but nothing seems to install?
Ad
  #2
Old 12-04-2007, 03:26 PM
randomfan randomfan is offline
Registered User
randomfan is on a distinguished road
On Nokia HK's website, MSN Messenger is available to download for free for the Nseries phones:
http://www.nokia.com.hk/nokia/0,,98969,00.html - 5th one down.
That page is for the N73, but the program works all the same - I've been using it on my N95 for over a week now!
Hope that helps.
  #3
Old 12-04-2007, 03:40 PM
Registered User
Thanks, I'll give it a try.
  #4
Old 12-04-2007, 07:19 PM
Registered User
Ok I've installed it but how do I run it? Theres no icon in the applications menu? Am I missing something?
Old 12-04-2007, 07:26 PM
Rafe's Avatar
Rafe Rafe is offline
Founder / Chief
Rafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of light
There should be an icon - check the bottom of the Applications Folder
__________________
Remember: The search command is your friend.
Feedback wanted: PM, email or post with your suggestions, complaints, feedback.
  #6
Old 12-04-2007, 07:34 PM
Registered User
It deffinently not there, I've installed other things which have appeard there. I'll try reinstalling.
I have found that alot of the S60 3rd Ed stuff wont install, keep getting the error "Installation of ****** Not Supported".
Shouldn't all S60 3rd ed apps work with the N95?
  #7
Old 12-04-2007, 08:33 PM
bingy_bongy's Avatar
bingy_bongy bingy_bongy is offline
Registered User
bingy_bongy is on a distinguished road
Found it !
The install creates a new folder, called internet - like on the N73/N80 etc ..
Shortcut is in there .. you can then move to whereever you like
__________________
Nk 2110 => Nk6130 => Nk7110 => Nk8850 => Sony Z7 (pants!) => Nk7650 => Nk6600 => Nk9500 => N80 => N95 => E90
  #8
Old 12-04-2007, 08:43 PM
Registered User
Cool, thanks! Don't know why I didn't see that earlier!
I take I just start it, then leave it running in the background to pickup messages? (I've never used MSN on a phone before!)
Ads
  #9
Old 12-04-2007, 08:46 PM
Registered User
yep thats about it (used it on my 9500) only thing to remember is thats its always 'online' so if your using 3G/GPRS might start to cost .. better to use Wi-Fi
__________________
  #10
Old 12-04-2007, 09:06 PM
Registered User
Not a problem for me, Orange have just given me a whole year unlimited date usage free, so I want to make the most of it!
Thanks so much for your help everyone!
  #11
Old 13-04-2007, 11:50 AM
jman200x's Avatar
jman200x jman200x is offline
Registered User
jman200x is on a distinguished road
thanks from me also, works nicely
much better than using eMSN in java
  #12
Old 24-04-2007, 07:52 PM
ajaybhadresa ajaybhadresa is offline
Registered User
ajaybhadresa is on a distinguished road
Hi installed messenger on my N95 and it worked fine for a couple of weeks. Now, however, when I try to log on it says the service is not available outside Hong Kong, China or Taiwan... Any ideas?
  #13
Old 24-04-2007, 09:05 PM
matimilko matimilko is offline
Registered User
matimilko is on a distinguished road
Msn
Quote:
YES on mine MSN nimm is the same! I noticed today!
  #14
Old 25-04-2007, 07:39 AM
LouieCoop LouieCoop is offline
Registered User
LouieCoop is on a distinguished road
Mine says the same, I only used it for one day :( someone help please... Might try re-installing it but I can bet the same error appears sooner or later...
  #15
Old 25-04-2007, 12:10 PM
Quakester2000 Quakester2000 is offline
Registered User
Quakester2000 is on a distinguished road
Quote:
Its blocked server side, it seems MSN china has caught on and blocked anyone outside china, taiwan or hong kong from using this version. Youll have to get software like QuickIM if you want to use MSN now.
Bookmarks
Tags
msn, n95
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Memory cards, handsfree kits etc for the N95 Andyhhh Nokia N95 and N95 8GB 0 10-04-2007 01:22 PM
N95 and GPS prateekb Nokia N95 and N95 8GB 1 15-03-2007 08:11 PM
TyTN --> N95 pgamble Nokia N95 and N95 8GB 9 09-03-2007 11:03 AM
Mobile Msn ciand06 Nokia 3230 2 22-06-2005 09:15 AM
Lets collect all data on this MSN matter. This is what I found working/not working em5 Motorola A920, A925, A1000, Benq P30 and P31 and Arima U300 2 31-10-2004 06:52 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
