All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 02-01-2003, 12:24 AM
J2theIZZO J2theIZZO is offline
Administrator
J2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud of
GPRS Settings
Can people maybe post their Network Operators GPRS Settings, stating country, Operator and possibly whether these settings allow non-restrictive data (Web access)
  #2
Old 03-01-2003, 03:42 PM
wahoch wahoch is offline
Registered User
wahoch is on a distinguished road
GPRS settings
I am having a devil of a time setting GPRS on p800 in Canada, nayone has the same problems? It works OK with my t68i yet same parameters do nt seem to work with p800. Wojtek
  #3
Old 04-01-2003, 04:00 PM
superschaf_007 superschaf_007 is offline
Registered User
superschaf_007 is on a distinguished road
GPRS settings
go to this link
http://www.sonyericsson.com/spg.jsp?...h the settings
  #4
Old 04-01-2003, 05:01 PM
Rear_Admiral's Avatar
Rear_Admiral Rear_Admiral is offline
Registered User
Rear_Admiral is on a distinguished road
Re: GPRS settings
Quote:
Originally Posted by superschaf_007
go to this link
http://www.sonyericsson.com/spg.jsp?...%3DS0%26B%3Die
Type in P800, then go to WAP configurator. It does it all for you, by sending an sms to your phone with the settings
Just had a look at this, it looks very good! It has got the settings for lots of providers (all of the dutch ones) and you can config GPRS, WAP, MMS and Email!
Couldn't test it, I am still waiting for my P800.... :cry:
  #5
Old 04-01-2003, 06:40 PM
Administrator
Re: GPRS settings
Quote:
Are't we all
Except those 'lucky' ones that got the early release date (BTW: I'm talking to any of you :P )
Ads
  #6
Old 05-01-2003, 11:29 PM
Guest
Posts: n/a
Cingular
I'm using the settings from:
http://navasgrp.home.att.net/tech/cingular/gprs_setup.htm
The first day I wasn't sure the settings were right because of some IMAP4 connection issues, but I tried again a few days later and everything worked. Cingular is obscenely priced for GPRS however, so for now I've got tho 1MB for $7US, but will probably move myself to the 7MB as it's been excessively useful.
  #7
Old 07-01-2003, 10:57 PM
opheim.com opheim.com is offline
Registered User
opheim.com is on a distinguished road
Netcom and Telenor settings (Norway)
I just published the wap/mail/gprs/mms settings for the two norwegian operators, Telenor and Netcom, on my site. The explanation is in norwegian, but the settings are done on my P800 running english software, so they should be understandable.
The WAP-settings for Netcom allows non-restrictive data, the Telenor settings I'm not sure of, since I haven't tested them yet. Netcoms WAP-account does not work for email, so you need a normal data-account for that, but it works fine for surfing html-content.
[edit]
php-nuke installed, all settings available through main-page; http://opheim.com
__________________
Hallvard Opheim
http://opheim.com
  #8
Old 09-01-2003, 01:35 PM
Tweak Tweak is offline
Registered User
Tweak is on a distinguished road
Can’t get my internet working :cry:
Did read manual, provider’s homepage, sms autoconfig and so on.
I get logged on by my provider (tried different providers in Norway and Sweden to different account including providers and home connection), but then I only see the SE logo jumping...
I am connected in 28,8 speed, and as soon I try to change page after about 45 sec it says error at server, but I am still connected :-? :-? :-?
So I have never seen the look when surfing or Wapping :cry:
Would be great if any could get me into right direction...
Maby I missed something importent ops:
  #9
Old 16-01-2003, 07:31 AM
Shadow Shadow is offline
Registered User
Shadow is on a distinguished road
well try this:
https://secure.mouse2mobile.com/clients/ericsson/jv/wap/new/default.asp
this is the site for each country !! please note: maybe you have to restart after receiving the settings !!
__________________
" Just because I Rock, doesn't mean i'm made of Stone !! "
  #10
Old 16-01-2003, 09:22 AM
Jott Jott is offline
Registered User
Jott is on a distinguished road
Swedish GPRS-configuration for Tele2 network
Tele2 in Sweden has now finally found out their GPRS-configurations. Call their support (+46) 0200-224050 and ask for someone that masters GPRS. They will hopefully soon publish an autoconfig-sms for P800 on their wapsite, http://www.tele2.se/wap.
  #11
Old 16-01-2003, 09:32 AM
Registered User
Hi Shadow!
Nope! Did not work :(
I tried that and also called SE support.
They never heard about that problem
Shipping the phone and get a new in 3 working days….
Hope that’s true!
The god news is that I am not that stupid!
  #12
Old 22-01-2003, 05:48 AM
jackalhead jackalhead is offline
Registered User
jackalhead is on a distinguished road
GPRS/WAP/EMAIL settings for the Philippines (Globe Telecom)
GPRS:
username - globe
password - globe
access point - internet.globe.com.ph
WAP via GPRS:
username - globe
password - globe
access point - www.globe.com.ph
EMAIL (SMTP server):
mail.globenet.com.ph
*note: these settings are only for GLOBE TELECOM subscribers; I am presuming you have already called (+632) 730-1000 and asked them to enable GPRS for your account; automatic set-up (ie texting "GO T68" to 2951) is not yet available for the P800.
__________________
I see your point... but I still think you're full of sh*t.
  #13
Old 25-01-2003, 12:16 AM
Guest
Posts: n/a
WAP config for Rogers AT&T - Canada
The WAP Settings should be:
Primary IP: 208.200.067.150
Primary Port: 9203
Secondary IP: 208.200.067.151
Secondary Port: 9201
The Data Settings should be:
GPRS
APN: goam.com
Username: wapuser1
Password: wap
Profile name: rogers
  #14
Old 29-01-2003, 11:22 AM
Guest
Posts: n/a
just testing
  #15
Guest
Posts: n/a
just testing
Bookmarks
Tags
gprs, settings
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
GPRS settings for Rogers AT&T network Canada (P800 only) Sony Ericsson P800, P900 and P910 5 06-12-2007 03:29 PM
Settings difference in GPRS WAP and GPRS INTERNET lanwarrior2000 Nokia 7650 7 21-05-2005 11:52 PM
Vodafone UK/P800 GPRS Internet and mail settings - THEY WORK rb14 Sony Ericsson P800, P900 and P910 15 10-07-2004 02:21 PM
P800 GPRS settings UK? gazcart Sony Ericsson P800, P900 and P910 2 31-01-2003 03:06 PM
T-MOBILE GPRS SETTINGS..?? mcse17 Nokia 7650 15 26-11-2002 01:39 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
