All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 03-12-2006, 10:03 PM
Cash's Avatar
Cash Cash is offline
Registered User
Cash is on a distinguished road
N80 - N80i firmware upgrade guide
IMPORTANT CHANGES
It is now possible to upgrade the N80 to N80ie with the Nokia software updater (NSU), you may have to change your product code with NSS http://rapidshare.com/files/5911866/nss10383.rar , EURO 3 code has been tried and works
If the above works then you don't need to do anything else, the guide will remain for others that are unable to upgrade with the above method.
Ok some people aksed for it so here it is including all downloads that work..
This is for European but you can use the APAC firmware instead if thats what you require
Firmware Euro
EMEA 15.00 Package:
http://www.megaupload.com/es/?d=ZTNNMFKD
EMEA 15.01 Update:
http://www.megaupload.com/es/?d=NHV66BID
Firmware APAC
http://rapidshare.com/files/5106380/....0632.0.38.rar
Pheonix bit torrent link
http://www.demonoid.com/files/detail...3503#file_list
Diego, cracks, reaper
http://rapidshare.com/files/5943056/...ack_reaper.rar
NSS
Instructions
First change product code with NSS to allow flashing to N80i
1, install NSS and run
2, plug in phone and select "pc suite" on phone
3, in NSS click "scan for new devices"
4, Click phone info
5, click enable product code and enter 0543922 (this is for Euro with English but other codes are below, if you want apac then remeber to use the apac firmware)
6, Click "write"
7, when complete unplug phone and exit NSS
UNINSTALL ALL RELATED NOKIA PROGRAMS AND DRIVERS, THIS INCLUDES NSS, PC SUITE, CABLE DRIVERS AND ANY PREVIOUS INTALLATIONS OF DIEGO, PHEONIX ETC.
Now run the 2 firmware files, 15.00 first and then 15.01 ( this is for euro)
Now to install pheonix
1, Run reaper, all instructions are included within reaoer, you dont have to download anything because all files are included here.
2, Follow instructions "how to install pheonix" (skip the download files part)
3, install Diego
4, open pheonix dongle crack (double click on it but dont install yet)
5, install pheonix untill it prompte for dongle not found.
6, click "retry" and run crack immediately and press "yes to all" in new window that opens, if done correctly then pheonix will continue to install normally, if you didnt do this correctly then close current pheonix installation and re-start pheonix installation from step 4 above - YOU HAVE TO DO THIS STEP VERY VERY QUICKLY OR PHEONIX WILL NOT INSTALL AND YOU WILL HAVE TO TRY AGAIN.
7, It may stop installing pheonix with "DESkey not found" click on yes twice then it will continue to register dll files (in some cases you will not get this message untill after you restart your computer if prompted after installation)
8, restart your computer.
9, copy pheonix crack and framework.dll into pheonix folder (this is the folder that you installed pheonic into . probably C:\Program Files\Nokia\Phoenix (but this may be different on your PC)
10, Run pheonix and enter your details...now pheonix will work.
To install firmware into your phone
1, back up your phone to the memory card, and then remove the memory card and sim
2, turn on phone and accept to use without sim
3, connect phone to PC with USB cable and select PC Suite
4, wait while the drivers are installed
5, you should have the latest firmware pages..if not then download via reaper
USB Flashing for N80
MAKE SURE YOU HAVE FULLY CHARGED BATTER (VERY IMPORTANT)
1, run pheonix and click file ->manage connections
2, click on the new button
3, tick USB and click next
4, it will find the handset connected via USB and click on next
5 it will display USB and click finish
6, Now place USB on top and click on apply -> close
7, click on file -> scan product
8, you will notice the handset has been detected, (look at the very bottom line of the window to see the phone info)
9 click on flashing -> sw update
10, select your product code (the code previously eneterd in NSS above) and click start
11, now pheonix will flash your phone...leave your phone alone EVEN IF THE SCREEN GOES BLANK AND YOU THINK ITS STOPPED UPDATING and do not dissconnect the usb cable as this will damage your phone.
12, after flash is complete a message will say "USB flashing successfull", your phone will boot up and will take 1 - 3 minutes to start so be patient
YOU NOW HAVE n80I PHONE
Notice you will have an internet folder, after you restore from your memory card the internet folder will dissapear and contents will be in "my own" folder.
I take no responsibility for any damage caused to your phone, this is entirely at your own risk, and this will also probably void your warrantee.
Product codes
Here are the product codes for both APAC and EMEA N80 Internet Edition
N80 Internet Edition Rm-92 APAC
0539367 HONG KONG Pearl Black Internet Edition
0539857 TAIWAN Pearl Black Internet Edition
0539858 APAC 1 Patina Bronze Internet Edition
0539859 APAC 1 Pearl Black Internet Edition
0539910 THAILAND Pearl Black Internet Edition
0540588 AUSTRALIA Patina Bronze Internet Edition
0540589 INDIA Patina Bronze Internet Edition
0540654 NEW ZEALAND Patina Bronze Internet Edition
0540779 PHILIPPINES Patina Bronze Internet Edition
0540782 INDONESIA Patina Bronze Internet Edition
0540783 THAILAND Patina Bronze Internet Edition
0540839 APAC 1 Smooth Stainless Internet Edition
0540841 THAILAND Smooth Stainless Internet Edition
0540843 AUSTRALIA Pearl Black Internet Edition
0540845 NEW ZEALAND Pearl Black Internet Edition
0540859 INDONESIA Pearl Black Internet Edition
0540860 PHILIPPINES Pearl Black Internet Edition
0540861 INDIA Pearl Black Internet Edition
0540862 PHILIPPINES Smooth Stainless Internet Edition
0540863 INDIA Smooth Stainless Internet Edition
0540864 AUSTRALIA Smooth Stainless Internet Edition
0540865 NEW ZEALAND Smooth Stainless Internet Edition
0540866 INDONESIA Smooth Stainless Internet Edition
0541538 TAIWAN Smooth Stainless Internet Edition
0541542 HONG KONG Smooth Stainless Internet Edition
N80 Internet Edition Rm-92 EMEA
0539362 ALPS Patina Bronze Internet Edition
0540868 ALPS Pearl Black Internet Edition
0542289 BALKANS Patina Bronze Internet Edition
0543252 BALKANS Pearl Black Internet Edition
0541428 BALTIAN Patina Bronze Internet Edition
0541440 BALTIAN Pearl Black Internet Edition
0542808 CIS, BULGARIA Patina Bronze Internet Edition
0542811 CIS, BULGARIA Pearl Black Internet Edition
0538301 EURO 1 Patina Bronze Internet Edition
0539363 EURO 1 Pearl Black Internet Edition
0539548 EURO 2 Patina Bronze Internet Edition
0539712 EURO 2 Pearl Black Internet Edition
0539473 EURO 3 Patina Bronze Internet Edition
0544109 EURO 3 Pearl Black Internet Edition
0539646 FRANCE Patina Bronze Internet Edition
0540867 FRANCE Pearl Black Internet Edition
0542814 GREECE, CYPRUS Patina Bronze Internet Edition
0542816 GREECE, CYPRUS Pearl Black Internet Edition
0539672 GULF Patina Bronze Internet Edition
0542489 GULF Pearl Black Internet Edition
0539673 ISRAEL Patina Bronze Internet Edition
0514757 ISRAEL Pearl Black Internet Edition
0542487 LEBANON Patina Bronze Internet Edition
0542488 LEBANON Pearl Black Internet Edition
0514753 MOLDAVIA, BELARUS Patina Bronze Internet Edition
0514755 MOLDAVIA, BELARUS Pearl Black Internet Edition
0514751 ROMANIA Patina Bronze Internet Edition
0514752 ROMANIA Pearl Black Internet Edition
0539652 RUSSIA Patina Bronze Internet Edition
0542699 RUSSIA Pearl Black Internet Edition
0539648 SCANDINAVIA Patina Bronze Internet Edition
0541439 SCANDINAVIA Pearl Black Internet Edition
0542490 SOUTH AFRICA Patina Bronze Internet Edition
0542525 SOUTH AFRICA Pearl Black Internet Edition
0539897 TURKEY Patina Bronze Internet Edition
0541690 TURKEY Pearl Black Internet Edition
0542703 UKRAINE Patina Bronze Internet Edition
0542810 UKRAINE Pearl Black Internet Edition
__________________
REMEMBER - If its too good to be true, it usually and probably is.....
  #2
Old 03-12-2006, 11:03 PM
cbcharlie cbcharlie is offline
Registered User
cbcharlie is on a distinguished road
is changing product code with nss necessary? i didnt do that, i just flashed.
  #3
Old 03-12-2006, 11:12 PM
Cash's Avatar
Registered User
Quote:
Maybe not, but its a simple process and only takes a couple minutes,
I didnt try without changing the product code, I thought its best to be safe than sorry as I read that you have to change the product code somewhere, and some people like the product code to be correct for their phone and the N80i.
I am not sure and may be corrected here, but it may have something to do with the languages that are installed in your phone..
__________________
  #4
Old 04-12-2006, 02:12 AM
waspin waspin is offline
Registered User
waspin is on a distinguished road
I get an error using phoenix... whein I go Product->Phone Information an error windows pops up:
I uninstalled every single nokia product as it says on reaper.
But when I go SW update it seems to be working as I can select the code and etc... Is that normal ?? I mean the error message regarding phone information and etc...??
Error while reading Info data from the provider.
Please check that the product is connected properly
and the connection has been established.
HRESULT 0x80004003 (-2147467261)
This means:
Ponteiro inválido
  #5
Old 04-12-2006, 09:12 AM
Cash's Avatar
Registered User
This means:
Ponteiro inválido
I waspin, I cant give you help with that error because I never experienced it, but somebody else here may have the answer for you ..
__________________
  #6
Old 04-12-2006, 09:59 AM
elaverick elaverick is offline
Registered User
elaverick is on a distinguished road
This sounds to me as though something is interfering with the connection between Phoenix and and your phone. First off check the most obvious things like ensuring that you have a good solid cable connection and that it's plugged into a verifiably working USB port.
The other thing that might be causing issues is if your PC Suite/Nokia Cable Driver didn't uninstall fully. If this is the case try the method I used and install Phoenix and Diego on a Virtual Machine. I used VMWare server (http://www.vmware.com/products/server/) which is nice and easy to get to grips with. Only thing to remeber here is that you give the Virtual machine access to the hosts USB ports in the Virtual machine settings. This method has the advantage that you can guarrentee you are running on a clean installation of Windows without having to format your existing PC.
  #7
Old 04-12-2006, 10:11 AM
Ratkat's Avatar
Ratkat Ratkat is offline
Registered User
Ratkat is on a distinguished road
You do not need to change the product code with NSS prior to flashing with Pheonix, the product code will be changed automatically by Pheonix dependant on the firmware you choose.
The idea of changing the product code using NSS was to allow people to upgrade their 'branded' phones to a 'non branded' firmware using the official Nokia Update Service (NSU). For example if you had a Vodafone N80 and connected it to the NSU you would be told there were no updates, once you had changed the product code using NSS it was then possible to update to the latest firmware using NSU
__________________
Symbian Phone History: 7650, P800, P900, N-Gage, 7610, 6630, 6680, N70 x 3, N80, 5500, N95, N95 8GB, E51, N82, E71, 5800x5, E75, N97, E52, Currently using: 5800
Cost Effective Web Design Nximedia
  #8
Old 04-12-2006, 10:12 AM
vin_eme vin_eme is offline
Registered User
vin_eme is on a distinguished road
Cash,
thanks for the neat steps....one more happy customer with N80i firmware...
~Cheers
  #9
Old 04-12-2006, 10:14 AM
Cash's Avatar
Registered User
Ok...so I can delete the part about NSS ?...this is the way that I did it and thats why I wrote the guide like that because I know it works .....
I didnt try flashing without prior changing the code, so I didnt write the guide like that..
In any case it doesnt harm the product, and the firmware will then be chosen automatically for you ... maybe a little easier for people who are not too technically minded perhaps..
__________________
  #10
Old 04-12-2006, 10:17 AM
Cash's Avatar
Registered User
Quote:
Originally Posted by vin_eme
Cash,
~Cheers
No probs, glad I could help
__________________
  #11
Old 04-12-2006, 10:38 AM
Ratkat's Avatar
Registered User
Ok...so I can delete the part about NSS...this is the way that I did it and thats why I wrote the guide like that because I know it works .....
As you say it won't do any harm and the firmware will be chosen automatically.
I wasn't knocking your guide (which is excellent by the way), just answering your post regarding the function of NSS
__________________
  #12
Old 04-12-2006, 10:41 AM
Cash's Avatar
Registered User
I know ...but I find its good to question somethings anyway because more info can be gained that way ..
__________________
  #13
Old 04-12-2006, 01:56 PM
Ratkat's Avatar
Registered User
So Cash as you flashed with the UK Country Variant 0543922,
if you hold down the # key does it change to silent profile, and then press again for back to general profile ?
mine didn't, so I reflashed it with Euro1 PB and it now changes profiles for the # key just fine
__________________
Ads
  #14
Old 04-12-2006, 01:59 PM
Cash's Avatar
Registered User
No it doesnt do that anymore when I hold it down :(..it just changes from numeric to alpha mode when I type to call somebody .. I guess this is for the SIP functions (did it do this before on the standard N80..I cant remember)
__________________
  #15
Old 04-12-2006, 02:21 PM
Nigma Nigma is offline
Registered User
Nigma is on a distinguished road
I can't get phoenix to run. As soon as i run the app, i get a splash screen flash then disappear. Followed by the standard windows error dialog asking if i want to send the results to Microsoft. The previos installs steps completed as describe in the guide. Any help would be much appriciated.
Thanks.
A.
Reply
Bookmarks
Tags
firmware, guide, n80, n80i, upgrade
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Next N80 Firmware Upgrade hoponhiggo Nokia N80 1 24-06-2007 05:22 PM
Orange Firmware with Nokia N80 stevehoot Nokia N80 18 08-11-2006 07:01 PM
N80 O2 Firmware Upgrade Leo Demetriou Nokia N80 13 23-08-2006 09:42 PM
Upgrade to new firmware V5.22 in US Gl4cier Nokia 9300 and 9500 18 08-08-2005 07:45 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
