All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
Go Back   All About Symbian Forums > Symbian Based Devices > S60 (Series 60) > Nokia N80
Reply
Thread Tools Display Modes
  #1
Old 22-05-2006, 04:57 PM
zail zail is offline
Registered User
zail is on a distinguished road
How to disable flashing blue light when in sleep mode..
sorry if this is a dim question but i haven't been able to find the answer in the manual or faq..
when the n80 goes into sleep mode the blue light at the top left flashes... is there any way to disable this or is there something that i am inadvertantly doing to get it to come on?? any help welcome as i am finding it really annoying! Great phone other than that though
  #2
Old 22-05-2006, 05:16 PM
Master_Payne Master_Payne is offline
Registered User
Master_Payne is on a distinguished road
Ive been having the same problem aswell, and in a dark room its really bright and annoying.
  #3
Old 22-05-2006, 05:21 PM
Ratkat's Avatar
Ratkat Ratkat is offline
Registered User
Ratkat is on a distinguished road
All you can do it turn off sleep mode, or do as I do place a bit of card over it at night.
__________________
Symbian Phone History: 7650, P800, P900, N-Gage, 7610, 6630, 6680, N70 x 3, N80, 5500, N95, N95 8GB, E51, N82, E71, 5800x3, E75, N97 Currently using: E52
Cost Effective Web Design Nximedia
  #4
Old 22-05-2006, 05:25 PM
Registered User
Quote:
lol I did that but its still annoying, what is the light for anyway?
  #5
Old 22-05-2006, 05:28 PM
Registered User
lol.. think i will opt for turning sleep mode off rather than the bit of card... v disorientatiing when u wake up in the middle of the night...
and why is it there at all???
  #6
Old 22-05-2006, 05:50 PM
Registered User
"sleep mode - select whether the display is switched off to save battery power 20 minutes after the screen saver is activated. When the display is switched off, a LED blinks to indicate that the device is powered on."
Thats from the help option on the phone.
It would be good to still have sleep mode but without the LED.
  #7
Old 22-05-2006, 06:51 PM
Registered User
certainly would be good... kind of seems to negate the point of sleep mode to have the flashing light
  #8
Old 22-05-2006, 08:16 PM
Dr, Who? Dr, Who? is offline
Registered User
Dr, Who? is on a distinguished road
Powering the LED will drain the battery a lot less than powering the screen..........
  #9
Old 23-05-2006, 12:55 AM
mrlitman mrlitman is offline
Registered User
mrlitman is on a distinguished road
It's perfect next to my Power Book with its throbbing LED. Now I have two lights to cover before sleeping.
  #10
Old 16-07-2006, 01:56 PM
Parm's Avatar
Parm Parm is offline
Registered User
Parm is on a distinguished road
It really is a nuisance, I can't believe there isn't an option to disable the flashing blue light in sleep mode.
Is it possible that somebody will someday make an app that gives the option of disabling it?
  #11
Old 16-07-2006, 02:09 PM
Cash's Avatar
Cash Cash is offline
Registered User
Cash is on a distinguished road
If its really a big problem then if you get some black nail polish you can just paint over it,
If you ever want to see the light again then the nail polish with scratch of quite easily without damaging the phone,
I find the light quite usefull because as my phone is always in sleep mode, and the battery tends to go flat quite quick, at least I am notified that the phone isn't working anymore.
and I think somebody mentioned here (I didnt test it so just going on hearsay) if you plug the charger in at night the light goes out (not sure how true that is though)
  #12
Old 16-07-2006, 02:23 PM
Parm's Avatar
Registered User
To be truthful, it's not the be all end all of problems. I find that just turning the phone over is a good enough sollution.
I just think it's a shame that Nokia didn't offer the option to disable it, it seems like such an obvious thing to have.
__________________
_______________________
www.parmmann.com
  #13
Old 16-07-2006, 02:33 PM
Cash's Avatar
Registered User
Haha, yes it seems that the obvious things to you and me seem not to be that obvious to Nokia.
Ads
  #14
Old 16-07-2006, 03:48 PM
nj7's Avatar
nj7 nj7 is offline
Registered User
nj7 is on a distinguished road
The things that I go discovering here. The N80 has a irritating LED to blink in the dark one... He seems like one SE phone then. This is bad, for more does not have a disconnect option...
  #15
Old 16-07-2006, 11:09 PM
louise501's Avatar
louise501 louise501 is offline
Registered User
louise501 is on a distinguished road
I have just got my little flashing blue light to work, I love it, I'm leaving mine on
Reply
Bookmarks
Tags
blue, disable, flashing, light, mode, sleep
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
