Kingston memeory card
13 replies · 2,877 views · Started 21 May 2006
I just bought a Kingston 1gb memory card (off ebay) for my N70. I've been having some problems whilst recording video with it. Although the audio works fine, the visuals get a but jumpy and can start and stop alot. Also, the image shown on the screen whilst recording is very jumpy indeed. Any tips that anyone can offer?
Hang on a second...are you sure you've set it to use the Memory Card rather than phone?
Also, is it an Orange phone, and do your videos open up in pvPlayer? Try opening your clips in RealPlayer, should be fine.
Finally, reformat your memory card with your N70 and try again.
Jon
Thank you VERY much indeed.
It isn't an Orange phone (I've heard about how they don't work well with the N70) and the film definitely wasn't going to the phone memory. The clips were playing in Real Player and it was all messed-up.
However, I've just formated the memory card as suggested and it's all working pefectly now. The screen image is smooth whilst filming and the final footage is too.
Thank you again, you've all saved me a fair bit of hassle.
The reason I got myself a 1gb card in the first place is 'cause I frequently use the phone to film bands playing live and the standard 64meg card isn't enough. Have a look at some of the (pretty good, if I can say so myself!) clips that I've had at
http://www.youtube.com/watch?v=bX9BJqUQ6d4
and
http://www.youtube.com/watch?v=RTjerqH37Ho
and this one isn't a band but it is funny
http://www.youtube.com/watch?v=wZnVnHUkMtw
Thank you all.
thanks guys - was havin the same problem myself (non-kingston card as well!) and fromatting solved the problem. Any ideas as to why this works though ? i was thinking maybe it stops the card becoming defragmented but am hoping not as i cant be bothered with formatting and re-installing all software once or twice a month once the card gets fragmented again 😞
mamoo_51 wrote:thanks guys - was havin the same problem myself (non-kingston card as well!) and fromatting solved the problem. Any ideas as to why this works though ? i was thinking maybe it stops the card becoming defragmented but am hoping not as i cant be bothered with formatting and re-installing all software once or twice a month once the card gets fragmented again 😞
A symptom of a card with slow transfer rates. Kingston is not the only card with slow transfer rates.
if its a slow transfer rate that causes the problem why does formatting the card fix the problem though ?!
mamoo_51 wrote:if its a slow transfer rate that causes the problem why does formatting the card fix the problem though ?!
Fragmentation is reduced, thus less searching and transfer(read/write) between card and OS. This has been discussed and proven on many s60 forums and threads.
which is also what (unfortunately) i had suggested in my post above 😡 surely im not goin to have to ditch ANOTHER memory card 😡
This is going to sound stupid but what is "formatting" the memory card and how do you do it because I bought a Kingston 1gb card off ebay and my videos suck?
Menu / Tools / Memory / Options / Format mem. card.
It wipes everything that is on the card and gives it a good clean-up. Worked a treat on mine when I was having bother with a Kingston 1gb card.
