because there were demanding mail to urged me to post the solution here...so i will give u all the solution...check it out....
1. u need the mp3 codec that i will give to u...u have to install the codec on ur phone
2. Important!!!!....the mp3 file must be save in joint stereo 128 bits 44.1Khz...u can make it using the Db power amp converter..if u dont have the converter, email me...i cant post it here because the file is big even in zip format..cant pass the max limit...sorry for the hustle...
3. How's the phone gonna accept the file...😎 ..it simple...the phone will accept the file when it has id3v2 tag....u can set it by using media player like winamp....just import the file to winamp playlist..right click and choose 'view file info'...
4. Now its ready...one more thing...u have to save the mp3 file in the original sound folder on ur memory card...done...
5. Plz give comment and any sugestion...this is my first post...i really hope that i can help u all....
Hey great!!! Tried it and works!!! Many thanks!!!
Been playing around... it doesnt have to be 128 bits for both ogg and mp3. It works with 64 bits and im assuming also other bit rate. Also, for ogg you can make it mono, but for mp3 it either has to be stereo or joint. When tried with mono, the mp3 plays very slow. Also the Khz doesnt really matter either for both format. you can also set it to variable. the only real thing that matters in order for the phone to recognize the format is the id3v2 tag. if its blank, then the phone will not recognize the files.
however, since the speakers for the 6600 isnt exactly good, you cant really hear much difference from a high bitrate and a low one. so to save space try it at 64 bits or lower @ 16 khz mono ogg format. Oh, also if its mono, the sound will play a little bit louder than stereo especially for the vocals or midrange which MAY sound muffled when played.
im a little bit upset with this forum...no offence mod..i just quite suprise that there are so many views in this thread but only a couple of reply post..maybe i should pull this thread off...:frown: 😡
:icon14: tryed it and works great thank you
When setup this program to SX1 it say "Can't loading. Series 60 Product ID required".
Is work on SX1?
i have got a virus in my nokia 6600 hand set. a logo appears on my phone" infected by comwarior" how could i get rid of it?
in my 600 a messange generate automaticaly & stay in outbox how could i cotrol it
cherr wrote:because there were demanding mail to urged me to post the solution here...so i will give u all the solution...check it out....1. u need the mp3 codec that i will give to u...u have to install the codec on ur phone
Hi i am facing problem with these mp3 codec. the bug is that for the first ring mp3 tone was played but after mp3 ring completed default tone rings.
one solution for this is to use long ringtones and for the other i am looking for.
any idea about this....
Thanks CHERR ,it works, totally cool application,u r great keep up the gud work.
i install the code ok
and no new icon will display
why
and what is the midea player
Definitely work. I was looking for solution about thiss matter for a long time but this works.Sound is pretty good (I don't know why many people complains about it) and its louder when its mono but it can not be ringtone then,you can only listen on MP3 player.
Congrats. foy solution dude!
well i encountered 2 problems in installing this codec
1: whn i started installin it...it gav an error "ur phone may not be compatable wid the s/w..do u wish to continue..yes/no...."........when i did yes...i finally installed the file....
2: another problem was tht no new icon was there...so do not know how to proceed further...please do reply soon
it still dont display on the screen
it there is new version for the code
and i think there is two program for the ringtone mp3 can u find it two plz:con?
hey dude it doesn't works in my n6600, i sent it through bluetooth so its the time of installing it says the application is not compatible with this phone...is this software for n6600 or not??if yes then why it gives me that sort of problem..do help me if theres another necessary way to make it..help will be appreciated..thanks and tc
can u send the code from your ----PC----
To my mail pliz
[email][email protected][/email]
Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaanks so match
hi buddy
i have installed tht file in my mobile but it is not responding when ever i m try to mp3 set as a ringtoone then there is errior file dosnt support plz tell me how i will use tht sis file
thanks
:icon14: Hats Off to you cherr.great work.....it really works.thanks a lot
i tried the attached sis files, at first it works, but then it wont play after a few hours, when there is a message, there would be no tone, its just like you made your phone silent. is there ant application that would really work on our phone after installing regarding of the hours after?
is there any application like making mp3 as a ringtone on 6600, other than what you have posted? i tried it, but its only good for a few hours after that, it wont work no more😊 ?
i tried to but the phone got hanged ,., & the ringtone(mp3) was garrbeled.. & was not in proper way.. 😞
HI,
if there is anything regarding ur nokia 6600 or any n60 series,please email me at [email][email protected][/email].....i will help all of u as far as i can....sorry not to reply to all of u quite some time...hope that i can give helps and suggestion to ur problem......😊 ...bye for now......
thanks a million:icon14:
perfect codec and instructions .
the fact my 6600 would not accept mp3s as ringtones was getting on my nerves since even the new crappy nokias now have that featre (like the 6060)
i love my 6600 but that and not having wifi access through it were the major things making me to think of changing my phone
btw i want to try the .wma type but dbpoweramp has more than one codec (WMA v9.1-----v2) which one should i use [FONT="Lucida Console"][/FONT]?
gr8sightman wrote:Hi i am facing problem with these mp3 codec. the bug is that for the first ring mp3 tone was played but after mp3 ring completed default tone rings.
one solution for this is to use long ringtones and for the other i am looking for.any idea about this....
i facing same problam can any one any idea abt that ? why the ring tone change after one bell
I cant get this thing to work.
I installed the sis file via usb. Installed on the phone its self. I downloaded DBpower amp and winamp and executed the steps in the order givin. When i play the mp3 on the phone and stop the music, choose options, and try to set as ringtone it says MusicPlayer: all ready in use. And if I go to profiles it still states the its not the right format. I have to be missing something please help!?
followed the guide and it works like a charm i can set my mp3 as tone now on my 6600 😊 thanks dude
Thanks.........This realy works like a charm
Thanks lot for software it is working 😊
I tried installing the mp3 codec and also saved mp3 file in the original sound folder of the MMC, but neither of them worked.
Pls help me so that i can set mp3 as ringtone on my nokia 6600.
Also pls let me knw the codec name so that i can reinstall it & try again.
thanks
