my nokia 3650 doesnt get past the nokia logo
10 replies · 2,829 views · Started 16 October 2005
i have tried everything i can but it wont work PLS PLZ PLZ PLZ PLZ🙄 can u help me
Unless you have the spare parts and required repair tools and equipment, and do not know what's really broken (what to fix), your best bet is with a repair center that has all that.
It may also be that the device is broken beyond repair and needs to be replaced.
have u got any codes or special ways of turning it on which will make it work? NO SHOPS. (by the way i dont like nokia shops.😮 .i have tried turning it on by holding down the green phone , no 3 and * but it dont work😡 .plz can anyone suggest something?
i really need my nokia 3650 fixed by friday so does anyone know how 2 fix a nokia 3650 which turns on, flashes the nokia logo about 6 times and then turns off? pls help me if u know any codes or special ways of turning it on i would wanna know answer me asap. any websites which anyone knows would be very gud.this prob started when i turned my phone on in safe mode and then i turned it off and then the prob started pls type in words that i can understand.HELP ME!😛cguru: :evil:
If you've tried removing your MMC card, powering it on holding the pencil, as well as powering it on holding Green + 3 + * you've pretty much tried all of the things you're able to try by yourself.
Unfortunately your options are probably limited to:
1. Taking your phone to a Nokia service center or sending it in to be reflashed
2. Spending big $$$$ on the hardware tools needed to do this yourself, as well as learning how to use them
3. Buying a new phone
best of luck
so the way to fix this problem is to flash and update the firmware of the cellphone?
i've got same problem in my 3650.
nokia logo showing 4 times, then it powers off.
