All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 11-10-2005, 01:01 PM
messus's Avatar
messus messus is offline
Registered User
messus is an unknown quantity at this point
N70 - Working- / Non working software
So far I have tested this software on the N70.
TomTom Mobile 5 (5.0.419) - Working
OGG Player 1.65 (unstable build) - Not Working (Hangs)
OGG Player 1.62 (stable build) - Not Working (Hangs)
SmartMovie 2.76 - Working
ProfiMail 2.32 - Working
AgileMessenger 2.64 - Working
FExplorer 1.13 - Working
SmartCom GPS 1.00a - Working
WorldMate 2.20 - Working
NetFront 3.2 - Working
Opera 8.00 - Woring (embedded)
My firmware is:
V 2.0536.0.2
12-09.05
RM-84
Please post your results with software, and your firmware and comments.
  #2
Old 11-10-2005, 02:41 PM
messus's Avatar
Registered User
SPMark 04 1.1.0 - Working (3d score: 988)
TaskSpy 0.96 - Working (220Mhz - ARM5)
Frodo C64 emulator 0.51.4 - Working
Switcher 1.50 - Not Working
SysInfo 60 1.30 - Not Working
ProfiExplorer 2.32 - Working
My firmware is:
V 2.0536.0.2
12-09.05
RM-84
  #3
Old 11-10-2005, 03:50 PM
Andy72 Andy72 is offline
Registered User
Andy72 is on a distinguished road
Igor Dontsov Alarm Manager v1.3.3 - Working (Great Program)
Mobileinttech Turbo MSN v1.00 - Working
My firmware is:
V 2.0536.0.2
12-09.05
RM-84
  #4
Old 15-10-2005, 07:01 PM
MAJ25
Guest
Posts: n/a
Installation Error message...
Hey guys... Im trying to Install:
guitartuner1.1
I keep getting the message Installation Security Error - Unable to install. Is there any way of bypassing this? Im guessing its because its not recognised software.
If anyone knows where I can I can get Handysafe for free - please let me know!!!
Also should the UK Voda version of N70 come preinstalled with world clock - mine doesnt have it... I think thats a bit of a con!
Look forward to your speedy responses
Cheers
  #5
Old 15-10-2005, 07:05 PM
MAJ25
Guest
Posts: n/a
Hi Messus!!!
PS Hey messus - remember me from the Sendo X forum?!!!
I now have to say, that the Sendo X was pretty damm good despite all my moaning. If it had been stable it would have been way ahead of its time and a superior phone. What a missed opportunity for the failed British company. The only real advantage to the N70 that I can see is the clear menus, 2mp camera of course and just better interface. Application wise its not hugely different to the X.
  #6
Old 15-10-2005, 07:13 PM
Rafe's Avatar
Rafe Rafe is offline
Founder / Chief
Rafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of lightRafe is a glorious beacon of light
You might also want to check:
http://www.allaboutsymbian.com/software/N70/
Software listed here (according to the author) is compatiable with the N70.
If you can not install software (poster above):
As stated in Steve L FAQ's:
"By default, some 6630 and other modern Series 60 smartphones come 'locked down' in terms of the applications they'll accept, installing only those that have large companies behind them, able to afford the expensive 'signing' process. But there are hundreds of other great applications, many of them free, that are 'unsigned'. Don't worry about this (see my malware article to put your mind at rest). Just go to 'Tools | Manager | Options | Settings' and turn 'Software installation' "On". (While you're in this dialog, make sure 'Online certif. check' is 'Off'. You can now install any compatible program without being blocked by spurious security warnings! "
__________________
Remember: The search command is your friend.
Feedback wanted: PM, email or post with your suggestions, complaints, feedback.
  #7
Old 15-10-2005, 07:30 PM
MAJ25
Guest
Posts: n/a
Nice ONE!!
THANKS - works fine now
still looking for Handysafe or an equivalent for free.... oh and world clock which Nokia left off!
  #8
Old 17-10-2005, 11:49 AM
messus's Avatar
Registered User
Hi, yes I remember you!
I don't wanna start a big thread about the N70 vs Sendo X, and that is not
what this thread is about.
Summarized I can not agree with you though, The N70 has twice the processor
power of the X, it has 6 times more internal memory (more apps run simultaniously), the N70 has S60 V2 OS which means FAR FAR better compatibility with more software (which this thread is about), it has 3G/Edge, it has Bluetooth V2.0 standard, it has USB 2.0 support, it has a MUCH MUCH better camera (and not only the resolution, but also the colour- and white-balance), the N70 switch songs (mp3) instantly and does not use 2-4 seconds as the X does, the N70 has a radio and the overall sound quality of the N70 is much better than the X, and lastly; the Sendo X looks good, but the silver look (and compact design and feeling) of the N70 is above all other smartphone I have ever tested!!!
I'll give the X credit for ont thing though, and that is the active desktop, which I think was really good, and better than the one on the N70.
Most important for me though is the compatibilty with TomTom Mobile 5 and QuickOffice with editing capabilities.
If you want to start a thread about N70 vs Sendo X, which I think makes no sense (two different worlds), I suggest you start a dedicated thread for it..
I started this thread for people to know which software that runs on the N70, and which software that "currently" does not.
Also many of the N-g**e games work on the N70, I got absolutely none to work on the Sendo X.
Sendo had a great opportunity, they wasted it!
  #9
Old 17-10-2005, 12:06 PM
messus's Avatar
Registered User
Have updated the list today..
WORKING APPS :
SPMark 04 1.1.0 (Free Edition) - Working (3d score: 988)
SPMark 04 1.1.0 (Full Business Edition) - Working
Alarm Manager v1.3.3 (Igor Dontsov)- Working (Great Program)
Turbo MSN v1.00 (Mobileinttech)- Working
Guitartuner1.1 - Working
BombJack 1.08 (J2M) - Working
ZipMan 2.31 (w/RAR plugin v1.0) - Working
YFtpClient v1.30 - Working
YEdit v.254 - Working
WirelessIRC 1.82.260104 - Working
SonicBoy Emulator v1.0 - Working
SuperGOBoy 1.0 (Emultaor) - Working
WiBMemTest 2.22.23 - Working
WiBCapture 1.37.47 - Working
Weather v0.3.9 - Working
Weather Center v.1.0.0 - Working
Vampent VSun v1.1 (Emulator) - Working
Nowire Teletext II v2.0.0 - Working
IM+ v5.14 (messenger - shapeservices) - Working
MobileSearch v.1.10.0 - Working
PicoDrive S60 v0.16.0 (Emulator) - Working
Pdf+ 1.37 / 1.36 - Working
EEMame S60 v1.1.0 (Emulator) - Working
AutoKeyLock v1.22.0 - Working
Adobe Reader v1.01 - Working
UltraMP3 v1.52 - Working
NOT WORKING (currently) :
Ads
  #10
Old 18-10-2005, 04:56 PM
cavey cavey is offline
Registered User
cavey is on a distinguished road
Handy programs
Have tried 4 Handy Programs from Epocware:
http://nokia-n70-software.epocware.com/index.html
Do not work:
Handy Safe v 2.2 => Fieldnames disappears when scrolling down, only values shows
Handy Dates v 1.0 => The same as above (You can use it, but it is tiresome to enter new dates)
Handy Shopper v 1.7 => Same as above when adding new items (or editing) (You can use it, but it is tiresome to enter new items (or edit))
Do work:
Handy File v 1.5
Epocware replied with that there was an error on their website, and that not every program is compatible with n70 all though it is listed on the n70-page.
V 2.0536.0.2
12-09-05
RM-84
Last edited by cavey; 21-10-2005 at 03:41 PM. Reason: added version number for the programs + my firmware version
  #11
Old 19-10-2005, 10:29 PM
fearby's Avatar
fearby fearby is offline
Registered User
fearby is on a distinguished road
Opera doesn't work
It didn't come preinstalled and the download version doesn't display text properly
  #12
Old 20-10-2005, 11:58 AM
john74 john74 is offline
Registered User
john74 is on a distinguished road
N70 WORKING..............
Advanced Call Manager v1.04 App manager 1.04
AutoKeyLock v1.22
FExplorer v1.11
FileMan v1.02
Profi Mail v new verisons only
Resco viewer v4.20.4
Slovoed v1.1
Smart Birthday v1.2
Smart Movie v2.50
Smart vCard v1.0
SMS Timer v1.31
Torch
UltraMP3 new versions
AGILE MESSENGER new version
MAGIC MINE
COLLAPSE
MICRO POOL
SPRITE BACK UP
HANDY PHOTO
RINGMASTER
MMS IT
WIB CAPTURE
E FILE MANAGER
GPL
WORLD MATE new version
CALL RECORDER
COCKTAIL
TUBE
VIKING MP3 PLAYER new ones
PUPPET MASTER
HANDY PROGRAMS
LOOK UP
CALLER INFO
contact guide alon
turbo msn
powerlock
FS caller new versions
tube
ms dictionary
eti camcorder 2
instant sis
natural recorder
city maps
eprofiles
egg clock
__________________
Symbian phones ruleeeeeeeeee
  #13
Old 21-10-2005, 09:56 AM
BigKingy BigKingy is offline
Registered User
BigKingy is on a distinguished road
You mean Full Screen Caller?
What version works on the N70? Version 3.0.0 doesnt seem to work. Does the latest 3.0.3 work?
  #14
Old 21-10-2005, 10:38 AM
fluid78 fluid78 is offline
Registered User
fluid78 is on a distinguished road
Thumbs up
Full Screen Caller 3.03 works fine on my N70.
__________________
N95
Vodafone
V 10.0.018
  #15
Old 21-10-2005, 11:36 AM
messus's Avatar
Registered User
AutoKeyLock v1.22
FExplorer v1.11
FileMan v1.02
Slovoed v1.1
Smart Birthday v1.2
Smart Movie v2.50
Smart vCard v1.0
SMS Timer v1.31
Torch
MAGIC MINE
COLLAPSE
MICRO POOL
SPRITE BACK UP
HANDY PHOTO
RINGMASTER
MMS IT
WIB CAPTURE
E FILE MANAGER
GPL
CALL RECORDER
COCKTAIL
TUBE
PUPPET MASTER
HANDY PROGRAMS
LOOK UP
CALLER INFO
contact guide alon
turbo msn
powerlock
tube
ms dictionary
eti camcorder 2
instant sis
natural recorder
city maps
eprofiles
egg clock
Thank you for your input John, but could you please specify specific version number on the software!? I have actually experienced that going up one version can reduce compatibility, so simply stating "newer version" may no be adequate to tell a user 100% wether the software will work in the phone. E.g. 3D Arts's Diamonds v.1.50 worked fine on the N70, but when I upgraded to v.1.60 it would not run at all!
Thank you again!
Bookmarks
Tags
n70, software, working
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Symbian Software pasa Community Waffle 14 28-04-2007 10:45 AM
Uninstalling Software and Other Question khkai Sony Ericsson P800, P900 and P910 4 14-01-2007 02:49 PM
Assigning some memory from disk C: to Working Memory Nokia 3650, 3660, and 3620 27 20-05-2004 08:38 AM
Bookmark: El Reg says MS admits its phone software poor Rafe Links of Interest 1 18-07-2002 01:03 PM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
