All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 12-11-2002, 02:21 PM
SKY SKY is offline
Registered User
SKY is on a distinguished road
ops Logo Help
Once set image as ops logo ~
the phone go reset
but the ops logo neber appear ~
Still the same ~
Y ???
Help needed ~
Phone with SelectQ <-- Paid Ver.
  #2
Old 12-11-2002, 02:56 PM
SKY SKY is offline
Registered User
Dear Big Brothers !!!!!!!
Pls Help me .
Something wrong with my phone ?
or ver. problem ?
my is 3.12
  #3
Old 12-11-2002, 02:58 PM
J2theIZZO J2theIZZO is offline
Administrator
J2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud ofJ2theIZZO has much to be proud of
Nope, have you re-named it with the XX_YYY_0.bmp using your ICC ID as the X's & Y's?
  #4
Old 12-11-2002, 03:51 PM
zygote zygote is offline
Registered User
zygote is on a distinguished road
Maybe a sticky Oplogo thread would be the answer here.
To answer the question though, either
a) You haven't named the file correctly, but unlikely as you are using SeleQ to set the image as the logo
or
b) Your operator name is hard coded into the SIM like BT Genie do and there is no way round this that I know of.
__________________
-----Z`/GoTe-----
  #5
Old 13-11-2002, 02:15 AM
seanmiguel seanmiguel is offline
Registered User
seanmiguel is on a distinguished road
or
AHA! there you go. this is what im talking about in the other thread that some operators coded a default logo in the sim which cant be overwritten!
i suggest use SeleQ, no renaming or anything like that necessary!
__________________
Sarap Mag Beer!!!
  #6
Old 13-11-2002, 09:47 AM
Shadow Shadow is offline
Registered User
Shadow is on a distinguished road
Hi Folks,
I'm new here and i've beeb following the discussions for quite a while now and i can't change my oplogo too! I'm from switzerland ( well, i'm from the philippines living in switzerland ) i did everything you told in this forum but i can't seem to change it!!
Any ideas??
  #7
Old 13-11-2002, 10:08 AM
Registered User
Quote:
Originally Posted by Shadow
Hi Folks,
Any ideas??
elaborate on what you mean you did everything, maybe we can point out where you missed out...
__________________
Sarap Mag Beer!!!
Ads
  #8
Old 13-11-2002, 10:20 AM
Registered User
Downloaded Seleq 1.20
installed it
downloaded a oplogo pic from here to try
save it as .bmp ( with my operators ICC or something )
send it to my phone via e-mail
save the pic
opened Seleq
made all the folders ( C:/system/Apps/Phone/Oplogo )
transfered the pic on that folder
selected it as an oplogo
phone rebooted
nothing
am i doing something wrong`???
  #9
Old 13-11-2002, 10:27 AM
Registered User
installed it
save the pic
opened Seleq
phone rebooted
nothing
hmmm, let me see, if you have the latest seleQ, which is 1.20i, all you have to do is browse the image, press options, select FILE, select SET AS OPERATOR LOGO, the phone will reboot and there you have it..
i hope this works, if it didn't then i dont know how else to help you - sorry...
__________________
Sarap Mag Beer!!!
  #10
Old 13-11-2002, 10:42 AM
Registered User
i already did that too!! didn't work!! should i take the picture under images_tn or just from the images?? i don't know maybe becuz my operator is sunrise ( formerly known as DiAx Swiss ) Sunrise bought DiAx for about 5 or 6 years but i'm stilll using an oler SIM Card!! it doesn't seem to change!!
  #11
Old 13-11-2002, 11:42 AM
alvinpaul alvinpaul is offline
Registered User
alvinpaul is on a distinguished road
I used SeleQ 1.20i to put my operator logo. Here are the screenshots of how i did it and the end result.
  #12
Old 13-11-2002, 11:59 AM
Registered User
i did that too!! but it just show the colored oplogo!! don't know why!!
  #13
Old 13-11-2002, 01:47 PM
Registered User
What do you mean by this? Are you installing a new logo and the previous logo still appears after the phone reboots?
  #14
Old 13-11-2002, 01:58 PM
Registered User
yes i'm trying to put a new colored oplogo and after rebooting the old one still appears!!! I'm pissed off to be honest!!
  #15
Old 13-11-2002, 02:09 PM
Registered User
When you go to c:\system\Apps\Phone\Oplogo you could see a bmp file there right? Try to rename your new oplogo (which should also be in bmp format) with the name of the bmp file in the said directory and overwrite the original bmp.
I hope this helps.
Bookmarks
Tags
logo, ops
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OPERATOR LOGO CHANGE NOT WORKING Nokia 3650, 3660, and 3620 14 04-07-2003 10:57 AM
Please help! How do I remove picture operator logo....... Rhythm Of Life Nokia 3650, 3660, and 3620 2 05-05-2003 04:38 PM
Operator Logo Shows And Then Dissapear Back To Orange Logo! DjYos Nokia 7650 8 23-11-2002 12:40 PM
Operator Logo - once more Yogesh Nokia 7650 10 22-10-2002 04:44 PM
any software to create and edit my ops logo like logomanager Nokia 7650 4 09-09-2002 08:48 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
