Sony Ericsson Update Service P910i
Update:
Phone: R4A006
Bluetooth: R2C
Organizer: R2A17
CDA: R2A16
P910i Maintenance Release 1 (MR1)
Organiser version: R2A17Quality improvement regarding document Viewers/Editors
General stability improvements
Pre-installed link to Application Shop added
Bluetooth stability improved
Added support for RIM BBC clients
MMS, colors and text selection doesn't always work, fixed
:cry: Hello, today my SMS application started crashing after I tried to perform an update at Sonyericsson.com, the update was interupted by the website server, saying "can't find device, remove battery and reinsert then start over", so I started over and over again, every time the same thing happened.
Now I get following error each time I turning on the device:
<titlebar> Program closed
Program Messages
Reason code CONE
Reason number 14
and when I try to use internet, I get this message:
Program Internet
Reason code BAFL
Reason number 4
The only thing I was doing is trying to update the organizer version, please kindly help me with this. Is there any way to reinstall individual system applications so I can just reinstall the SMS and/or Internet application?
Or should I take it to service department?
Appreciate your time!
Try to update your P910 again or make restore if you have a backup !
has anyone attempted to flash their p900 with the p910 update service?
It doesn't work! If you want your P900 flashed with a P910i firmare you must send your phone away to one of the several individuals currently offering the service privately. However, you will (as things stand) loose your bluetooth (though someone claims to be working on a fix for this).
CAN p-900 owners can upgrade their phone to p-910i firmware.
Have you read Bassey's reply? All the answers in there...
nick111 wrote:Sony Ericsson Update Service P910iUpdate:
Phone: R4A006
Bluetooth: R2C
Organizer: R2A17
CDA: R2A16😊
