04-07-2004, 06:51 PM
7610 Moderator
converting mp3 to AAc?
is there any program come which convert mp3 to aac
and cut mp3 easily
04-07-2004, 06:56 PM
Registered User
Quote:
and cut mp3 easily
U can try to use MP3 AUdioconverter to convert mp3 to aac and use mp3 trim to cut mp3 which i m using now. thx..
04-07-2004, 07:13 PM
7610 Moderator
from where i can download it
06-07-2004, 05:38 AM
Registered User
You could burn your favourite MP3s onto a CD, and use Nokia Audio Manager to rip them to AAC 64kbps.
What I do, is use DB Amp Power Convertor and convert all my songs to (still mp3 format):
Encoding: Constant Bitrate
Bit Rate: 24 Kbps
Channels: Mono
Frequency: 16000 Hz
Hope that helps!
__________________
Nokia N80 now. Gotta update my avatar someday ...
06-07-2004, 12:53 PM
Super Moderator
Or,you could just use Nero to make a Image,mount it and fool Nokia Audio Manager that its a real CD or even simpler,you could use Easy CD-DA Extractor for a direct conversion.
__________________
www.symbiandiaries.com/ghostdog
Please don't PM me with something that belongs in the forums. Search first,then ask.
06-07-2004, 01:32 PM
Registered User
Quote:
You'll have to teach me that soon. I can't stand burning music to CDs then ripping them to AAC format again thru Nokia Audio Manager ...
*faints*
__________________
06-07-2004, 02:48 PM
Super Moderator
You can find a small guide here.If you need more details,let me know.
__________________
10-07-2004, 12:46 AM
Registered User
You could easily use iTunes to rip/convert from mp3 to AAC as well. It will also allow you to edit the files; are you using Mac or Windows? Mac has a program called SoundConverter you can use to edit if you don't want to use Quicktime. Windows has too many to mention but I normally will use Nero Wav Editor on my Windows box.
10-07-2004, 01:41 AM
Super Moderator
I believe that iTunes encodes in to mpeg4 AAC only.Can the 7610 play mpeg4 AAC or just mpeg2 like the N-Gage?
__________________
10-07-2004, 03:04 AM
Registered User
Nokia lists the playback as "Viewing formats: 3GPP, MPEG-4, H.263, Real Video." My-symbian lists the following formats as supported multimedia: "AMR, WAV, MIDI, AU, Real Audio, Real Video, MPEG-4, AAC, MP3." I haven't tested an iTunes AAC file on my 7610 but apparently it should support the expected playback. I'll test and post my findings.
10-07-2004, 04:36 AM
Registered User
Problem with iTunes is, they converted all my MP3s to M4As. Don't know why it did that. I even selected "AAC 64kbps" in Options/Preferences
DB Power Amp Convertor is unreliable in converting MP3 to AAC.
As i'm using the 7610, i'm converting all my favourite MP3 to a lower bit rate and mono sound
__________________
10-07-2004, 11:51 AM
Super Moderator
Those are video formats,not audio,the second ones you listed are audio.
Because M4A is mpeg4 AAC.I believe the 7610 can only play mpeg2 AAC.
__________________
14-07-2004, 07:28 PM
Registered User
If you really do care about file size, I recommand you to use .ogg files. The compression rate is better than AAC, and it is very easy (with CDex for example) to create file in mono.
OggPlay is a freeware open source SW that can play those .ogg files on S60 phones.
On 6620 and 7610, it also can play AAC and MP3. If you have one of these phones, (and want to play either AAC or MP3) use this link:
http://sourceforge.net/project/showf...group_id=86146
If you do not have 6620 or 7610 Nokia phones, or do not care about MP3/AAC, the official version is probably better (works with all S60 phones):
http://symbianoggplay.sourceforge.net/
Evobit has made some nice skins for OggPlay, take a look there:
http://www.allaboutsymbian.com/forum...ad.php?t=25511
26-07-2004, 01:12 PM
Registered User
Are AAC better/lower quality than MP3?
Are they smaller/larger files than MP3?
If someone only needed to listen to music files occassionally with a hands-free set, which is the one to go for in terms of 'reasonable quality'?
Thanks.
27-07-2004, 08:42 AM
Registered User
AAC 64kbps is equivalent to the quality of a MP3 128kbps
However, an AAC 64kbps would be smaller (considerably!) than a MP3 128kbps
Not too sure about a handsfree set. I'm still waiting to test my HDS-3 Stereo Dual Headset on my 7610
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
