All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #1
Old 22-02-2004, 03:37 AM
bugless bugless is offline
Registered User
bugless is on a distinguished road
wav ringtones?
I see a lot of links to wav files as ringtones, but I can't seem to get them to work. Instead I use WB-AMR files, which have rather poor quality and a low volume. My friend has wav ringtones on his 7650 (taking up most of his memory!) and I would rather have wav files. Whenever I send a wav file to my phone, and try to browse available ringtones the phone won't recognise the wav file as a valid ringtone.
Am I missing something? Is there a size limit to the ringtone? Do I need it on the phone memory? Do I need it in a certain folder?
Please help, as I am missing calls cos my ringtone is too damn quiet.
Ads
  #2
Old 22-02-2004, 10:42 AM
D-Coder D-Coder is offline
Registered User
D-Coder is on a distinguished road
Hi mate
I don't know how you did it but let me show my ways.
1) Choose a mp3 or wav file. Connect your phone to pc via IR or BT. Open Pc Suite and put your file into "Sound Files>Digital" folder. File conversation begin automatically by pc suite.
2) Choose a mp3 or wav file. Open that file by your favorite sound processing program (mine is goldwave). Save your file as acceptable wav file (gsm 22,050 khz mono or gsm 44,100 khz mono options available in goldwave). Connect your phone to pc via IR or BT. Open Pc Suite leave file conversation off in configuration. And put your file into "Sound Files>Digital" folder.
Let Pc Suite handle your file conversation if you don't know how. Or search forum, there was a thread about mp3 to wav file conversation.
I hope that's help you.
__________________
the other side of the medallion
  #3
Old 22-02-2004, 09:36 PM
Turtle Turtle is offline
Registered User
Turtle is on a distinguished road
To be honoust, you can leave Sound Conversion on, but that;s my opinion.
If your samples are in good quality they will stay at a nice quality, but that's my opinion. As long as you do not have a € 100000 speaker set attached to you mobile, why use lot's of space while a little less quality (i can't hear the difference) uses lot's less space.
But you must use the PC Suite, using BT --> send to... option cut's of the beginning and end of a sample. :(
Use the suite as mentioned in other posts, and place the either on your MMC card or phone memory in the folder: sounds\Digital or create your own subfolders.
That should work.
Reply
Bookmarks
Tags
ringtones, wav
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
