All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #46
Old 01-07-2005, 08:34 PM
amitdotchauhan amitdotchauhan is offline
Registered User
amitdotchauhan is on a distinguished road
video tone use the mpg or 3gp files as ring tone
  #47
Old 04-07-2006, 12:56 AM
sabre sabre is offline
Registered User
sabre is on a distinguished road
connected N-gage with USb cable
friends.tell me how to connect N-gage with UsB cable....i've been trying, but i can't get connected. Shouldy i connected my N-gage with PC suite with bluetooth....tell me how?plz
  #48
Old 10-09-2006, 06:00 PM
madyasth madyasth is offline
Registered User
madyasth is on a distinguished road
how to flash n gage qd
pls tell me how to format or flash the n gage qd
my email id is mady5@rediffmail.com
  #49
Old 14-09-2006, 07:16 AM
pangie's Avatar
pangie pangie is offline
Registered User
pangie is on a distinguished road
bro madyasth... reformate code for NGAGE *#7370#
and make sure ya back up contact and etc
batery in FULL...ok
bro sabre, i dont think ngage can use usb... coz dont have...PCsuite for it..
bluetooth or use CARD READER much better....
but ya gota have SELEQ or Fileman or Fexplorer.....ok
if ya need more help or helper.... PM me ya....
__________________
Click me
  #50
Old 11-11-2006, 08:05 PM
sizzler_guy1's Avatar
sizzler_guy1 sizzler_guy1 is offline
Registered User
sizzler_guy1 is on a distinguished road
Smile hello friends can any1 know tat...................
hello all..........
i want to know tat is there any software through wich we can send mms free??
if any1 know then please reply as soon as possible .....ok bye bye take care all....
__________________
BAASHER
  #51
Old 10-12-2006, 11:42 AM
YURA YURA is offline
Registered User
YURA is on a distinguished road
Thank's Bro.... It's Help a lot !!!
Ads
  #52
Old 15-12-2006, 03:39 AM
nikhil2005arora nikhil2005arora is offline
Registered User
nikhil2005arora is on a distinguished road
Exclamation ringtone volume problem
My Ngage is behaving rather strangely lately. When i go to profiles and select the ringtone, be it Mp3 or midi or Wav it seems to be rather loud, as it should be but when i have selected the tone that i want and try calling it from another phone the ringing volume is very low.
It was not like this before. It was working fine for few months, there is nothing wrong with hardware as it is loud as usual when selecting tones or playing them individually using the built in recorder application. this problem only started few days back.
1.) it is not set to ascending volume.
2.) firmware 4.03
3.) tried without the mmc card by copying the tone into c: drive
4.) removed dBprofile.db from c:\system\profileapp
5.) format *7370# at least 6 times.
6.) tried deleting most files out of C:\ and D:\ and then *7370#
7.) everything ELSE works just fine except this !
my question is, after formatting the only source of operating system files are from the ROM Z: drive. is it really possible that the ROM copy of the dbProfile.db source has been corrupted ? or the firmware is generating corrupted copies of the dBprofile.db every time i format. it also generates new copies of the dBprofile.db everytime is just delete the dBprofile.db and SOMETIMES the volume gets back to normal, but if the profile application is opened and closed the problem comes again.
Any of you guys here facing this problem ?
thanks in advance.
  #53
Old 15-12-2006, 06:07 AM
pangie's Avatar
Registered User
bro....
wat mobile/model are ya using....
do ya install FullCaller app and wat version too......? or any app?
or izit... after reformate ... ... without install anything...
the problem was starter....
pls let me know ya....
__________________
Click me
  #54
Old 15-12-2006, 08:19 PM
Registered User
m using NGAGE1 d original one wid firmware version 4.03 , i've not installed nykinda applications u mentioned above, jus a few games, some of d apps i've installed r
*smart movie
*pExtender
*Pdf+
*BLZ installer
*MSV drivee
yup dats it ,on ma 512 mb MMC n volume of ringtone izz real bad..plzzz help
  #55
Old 16-12-2006, 02:57 AM
pangie's Avatar
Registered User
go to myplace ya.....
see ya
__________________
Click me
  #56
Old 18-12-2006, 11:55 AM
webguru webguru is offline
Registered User
webguru is on a distinguished road
2.) firmware 4.03
thanks in advance.
Hey nikhil,
Its quite possible that the dBprofile.db is corrupt in your cell. If you have installed a software recently especially a ringtone/sound related software, then uninstall it. If it doesn't get fixed, take your cell to an authorised nokia service center and request them to install the OS again, this should rectify the problem.
__________________
Nokia 5800 XpressMusic Blog
  #57
Old 19-12-2006, 05:45 AM
pangie's Avatar
Registered User
bro webguru...
nikhil2005 was fix...
wat ya said was right...she got probelm with smartmovie app....
probably version problem...
bro guru... y dont join me...
see ya...
__________________
Click me
  #58
Old 17-02-2007, 05:07 PM
Archangel Archangel is offline
Registered User
Archangel is on a distinguished road
I've a problem. My device memory is kinda full. I dnt knw how but only abt 1.5 Mb is free. Although I've lots of space in my MMC. Now the problem is that I can't install any software because it says device memory low, delete some data. I dnt hv any pics or ringtones in my device memeory stil its full.
So can somebody help me as to how to install new softwares. Even a 600kb software also says device memory low.
  #59
Old 17-02-2008, 04:47 PM
azehar18 azehar18 is offline
Registered User
azehar18 is on a distinguished road
help
how to install pc suite for n-gage qd..
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
