Games for the weekend
10 replies · 3,598 views · Started 17 May 2003
If you're stuck again at your computer and you're bored, click http://www.bossmonster.com/bossframe.html There's plenty of pretty entertaining games, you can e.g. shoot at planes or pinguins or burst bubbles 😃 . I didn't try all the games yet so I can't tell you more but the graphics was kinda cool. Enjoy 😃
Enter The Matrix
Cheat mode:
Enter the Hacking engine in the game. Then, unlock the command allowing "cheats". Enter one of the following codes to activate the corresponding effect.
Effect Code
Maximum firepower 0034AFFF
Unlimited ammunition 1DDF2556
Unlimited focus 69E5D9E4
Fast focus restore FFF0020A
Unlimited health 7F4DF451
Sparks' Construct in training mode 13D2C77F or 1302C77F
Enemies cannot hear you 4516DF45
Enemies cannot see you FFFFFFF1
Turbo mode FF00001A
Multi-player fighting D5C55D1E
Low gravity BB013FFF
Faster logos 7867F443
Bonus stage 1302C77F
Taxi Driving 312MF451
Hacking engine tools:
In Hacking engine (which is accessed from the title screen), there are a number of directories and tools that can be useful (such as spawning a weapon within The Matrix.).
Command Effect
DIR <location> List files and folders
CLS Clear the screen of text
HELP <command> Extended help for a command
TRACEKILL Kills traces
READ Read *.txt files
VIEW View *.img files
PLAY Play *.fmv files
DROP JXTRR10 Weapon drop at Drainage Canal
DROP PNSRZ10 Weapon drop at North Concourse
DROP RKHMS10 Weapon drop at Airport Tunneld
DROP JDZMT10 Weapon drop at 2nd Floor West (Chateau)
DROP ZKHBD10 Weapon drop at Courtyard (Chateau)
DROP RHFTQ10 Weapon drop at Skyscraper
DROP ZSZQH10 Weapon drop at Warehouse (Chinatown)
DROP JDHQL10 Weapon drop at Transformer Field (power plant)
DROP B1AXXF2 Weapon drop at 2nd Floor PO Boxes
Morpheus message:
In the Hacking engine, instead of using "GUEST", you can LOGIN as FREEMIND or COWBOYCURTIS to hear a message from Morpheus.
Information in this section was contributed by Neurozys Jackowicz. Phone numbers:
001-949-555-0112
001-714-555-0187
001-213-555-0142
001-310-555-0111
001-949-555-0101
Hint: Finding cheat codes:
Every highway sign you see in The Matrix: Reloaded is a cheat for the game, Enter The Matrix.
Hint: Airport level: Take out helicopter:
During your battle with the helicopter as Ghost, use the following strategy. Focus Run across the room to where the wall starts to curve. Back up against the wall facing the away from the large glass window. Hold Auto Aim and when the SWAT starts to jump down through the window, use your Focus and dispatch them with the least amount of ammunition possible. Go back to where you were against the wall earlier and wait for the helicopter to pass over. When it does, it will shoot the wall. If you are in the correct location, it will not hit you. After you hear the bullets stop, run around the wall and the helicopter will be exposed without any protection. Use your Focus and dump at least a clip into it. Then, return to the wall and repeat the process. It only takes three to four times to take down the helicopter.[/b]
[quote="Edgedale"]The game for this coming weekend will be Enter The Matrix!!!! 8)
Agent Smith is cool....[/quote]
nice game but it still needs some work :-?
i have it on the PS2 and the GameCube
and it still needs some work :-?
BTW it says in the maual that you can find the cheats for the game on street signs in the movie 8)
Yeah that's correct.... inside the hacking room.. you can do it.... and also the telephone numbers too... 8)
