All About Symbian - Nokia (S60) and Sony Ericsson (UIQ) smartphones unwrapped
  #31
Old 09-10-2007, 07:09 AM
tanov tanov is offline
Registered User
tanov is on a distinguished road
sometimes the hands land in the applications folder plus you may need to copy in the files:-
tt6.exe
cheers
wayne
  #32
Old 09-12-2007, 04:02 PM
naushadhassam naushadhassam is offline
Registered User
naushadhassam is on a distinguished road
hi
where can i download the tomtom6 for n95?
Ads
  #33
Old 09-12-2007, 06:49 PM
nottmbantam's Avatar
nottmbantam nottmbantam is offline
Registered User
nottmbantam is on a distinguished road
Quote:
Originally Posted by felixcatster1 View Post
Got to Say I agree with the Porter and Nudda about the totally unhelpful
- Have You Tried Tomtom Customer Support?- Quote from henklbr and his Parrot Bartmanekul and the answer is No and not going to either, is that OK for You?
Plus henklbr who are You to question if my software is legit? - is there anything else You want to stick Your nose into????
I just got fed up with the Tomtom 6 Software, bought CoPilot 6 instead haven't had chance to try it yet though.
TT6 - too much like hard work !!!!!!
In terms in installing TT6 - do you need the relevant .sis files? After installing TT6 files and folders to your root folder on the MMC, you probably need to run the sis file to get it install?
I had CoPilot for N95 but basically, I much prefer using TT6 with an external BT GPS unit, rather than the clunky CoPilot with internal gps. I had an external unit beforehand anyway ( was using TT5 on my Nokia 6680 ).
Good luck.
__________________
Silver E72
FW: 052.005
31.10/2010
RM-530
E72-1
  #34
Old 10-12-2007, 02:13 PM
andykn andykn is offline
Registered User
andykn is on a distinguished road
Quote:
Originally Posted by naushadhassam View Post
hi
The tomtom website.
  #35
Old 10-12-2007, 02:16 PM
randomfan randomfan is offline
Registered User
randomfan is on a distinguished road
Quote:
Originally Posted by andykn View Post
The tomtom website.
  #36
Old 10-12-2007, 02:18 PM
Registered User
Good luck.
I used the Tomtom Home software. It copies everything to the mem card wherever it's supposed to go and then the phone will show the icon in the Application folder from where it can be run.
  #37
Old 10-12-2007, 02:32 PM
Dogmann's Avatar
Dogmann Dogmann is offline
Registered User
Dogmann is on a distinguished road
Hi all
Well the solution is not that difficult, go to the App Manager and scroll down the list of Apps until you find Tom Tom then click options install. After this you will be able to find the two Red hands and then move them to where you want and start the app hope that helps you.
Marc
Bookmarks
Tags
installing, n95, tomtom
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
TomTom and n95 built in gps scotjen1 Nokia N95 and N95 8GB 38 11-02-2009 11:33 AM
Problem installing TomTom Navigator 6 marrrin Nokia N71, Nokia N73 and Nokia N75 12 15-09-2008 09:35 PM
Does anyone have tried installing Tomtom Navigator 6 on N73 tamolmol Nokia N71, Nokia N73 and Nokia N75 33 19-02-2008 02:42 PM
TomTom makes modular City Maps and Route Planner available Rafe Series 80 5 13-07-2005 04:00 PM
installing TomTom Citymap with Apple? m.timmer Nokia 6600 and 6620 2 20-02-2004 09:31 AM
vBulletin skins developed by: eXtremepixels
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright Notes || Contact Us || Privacy Policy
